How do I add a counter / repeat / while loop to repeat one step (add multiple lines to a table)??
Question asked by Patrick Malone on Nov 12, 2015
Latest reply on Nov 18, 2015 by Patrick Malone
This is another users code for adding a line to a table (BOM)
(Will have to look for the actual post to credit properly..)
At the bottom of the code is this line:
ret = myTable.InsertRow(swTableItemInsertPosition_Before, i1)
I have simply copied the line the number of lines I want to add to my table.
Works just fine for my purposes!!
In desiring to learn more I was thinking that I would like to get the routine to ask me
how many lines I'd like to add to my table then have it repeat the above line (that one step) that many times...
I assume its a counter or a while loop.
This code works.
Hoping someone will have some mercy on me..
Option Explicit
Option Compare Text
Dim Part As ModelDoc2
    Dim myTable As TableAnnotation
    Dim selMgr As SelectionMgr
    Dim i1 As Long
    Dim i2 As Long
    Dim i3 As Long
    Dim i4 As Long
    Dim ret As Boolean
    Set Part = swApp.ActiveDoc
    If Part Is Nothing Then Exit Sub
    If Part.GetType <> 3 Then Exit Sub
    Set selMgr = Part.SelectionManager
    If selMgr.GetSelectedObjectCount2(-1) <> 1 Then Exit Sub
    If selMgr.GetSelectedObjectType3(1, -1) <> swSelANNOTATIONTABLES Then Exit Sub
    Set myTable = selMgr.GetSelectedObject6(1, -1)
    myTable.GetCellRange i1, i2, i3, i4
'Copy following line for the Number of lines you want to add - 5 entries = 5 new lines to the table
' ret = myTable.InsertRow(swTableItemInsertPosition_Before, i1)
Thanks in advance!
