3 Replies Latest reply on Nov 11, 2015 2:32 PM by Deepak Gupta
    2016 broke my macro that was written for 2014, help
    Tyler Holden
      My macro as shown below, worked great in 2014, it is broken in 2016.  I click the macro button and solidworks sits there frozen and i end up having to close it and restart solidworks.  Please advise.
      'Export Drawing as DXF_PDF (Revision).swp ------------- 01/29/15
      'Description: Macro to save active drawing as PDF and DXF.
      'Pre-Condition: An open drawing with one view.
      'Post-Condition: Macro save active drawing as PDF and DXF in specified location with referenced model file name
      '                along with drawing revision as exported file name in the file name.
      'Please back up your data before use and USE AT OWN RISK
      ' This macro is provided as is.  No claims, support, refund, safety net, or
      ' warranties are expressed or implied.  By using this macro and/or its code in
      ' any way whatsoever, the user and any entities which the user represents,
      ' agree to hold the authors free of any and all liability.  Free distribution
      ' and use of this code in other free works is welcome.  If any portion of
      ' this code is used in other works, credit to the authors must be placed in
      ' that work within a user viewable location (e.g., macro header).  All other
      ' forms of distribution (i.e., not free, fee for delivery, etc.) are prohibited
      ' without the expressed written consent by the authors.  Use at your own risk!
      ' Written by: Deepak Gupta (http://gupta9665.com/)
      Option Explicit
      Dim swApp           As SldWorks.SldWorks
      Dim swModel         As SldWorks.ModelDoc2
      Dim swDrawModel     As SldWorks.ModelDoc2
      Dim swDraw          As SldWorks.DrawingDoc
      Dim swView          As SldWorks.View
      Dim swExportPDFData As SldWorks.ExportPdfData
      Dim nErrors         As Long
      Dim nWarnings       As Long
      Dim Revision        As String
      Dim PartNumber      As String
      Dim nFileName       As String
      Const Path          As String = "\\WDMYCLOUDMIRROR\Public\QuadM Release Drawings" 'Change the path here
      Set swDrawModel = swApp.ActiveDoc
      ' Check to see if a drawing is loaded.
      If swDrawModel Is Nothing Then
              MsgBox "There is no active drawing document"
              Exit Sub
      If swDrawModel.GetType <> swDocDRAWING Then
              MsgBox "Open a drawing first and then TRY again!"
              Exit Sub
      Set swDraw = swDrawModel
      Revision = swDraw.CustomInfo("Revision")
      If Revision = "" Then
              Revision = ""
      Set swExportPDFData = swApp.GetExportFileData(1)
      swExportPDFData.ViewPdfAfterSaving = False
      Set swView = swDraw.GetFirstView
      Set swView = swView.GetNextView
      Set swModel = swView.ReferencedDocument
      ' Determine if there is any view
      If swModel.GetPathName = "" Then
              MsgBox "Insert a View first and then TRY again!"
              Exit Sub
      'Get Model Name
      PartNumber = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
      PartNumber = Left(PartNumber, InStrRev(PartNumber, ".") - 1)
      nFileName = Path & "\" & PartNumber & " " & Revision
      'Save as DXF
      swDraw.SaveAs3 nFileName & ".DXF", 0, 0
      'Save as PDF`
      swDraw.SaveAs3 nFileName & ".PDF", 0, 0
        • Re: 2016 broke my macro that was written for 2014, help
          John Alexander
          When you get the error, what line does the debugger point to and what is the error?
          Edit: Sorry, poor reading comprehension on my part.
          I don't have any way of testing your code (2014 is highest release available to me) but I can suggest how to proceed. Your macro is hanging somewhere, you need to identify what function call is causing the issue. When the program starts to hang, you can use the "Pause/Break" key on your keyboard (I think it's shift+break or cntrl+break) to kill the macro during execution. When this happens, the debugger should open with the current line highlighted. This will inform how to proceed with your debugging.
          If solidworks is actually frozen, the above approach may not work. One alternative is to insert several Debug.Print statements in several places in the macro. You can use these print statements to see how far the macro got before it started to hang. The print statements will display whatever you want them to in the vba editor's Immediate Window. In this case, you have to run the macro with the editor open.
            JOHN GEORGE
            Tyler,
            It's working fine here in 2016
            You need to modify this line
            Specify the folder "-----------"  to save location
              Deepak Gupta
              Can't check it but make sure this path exist and you've write access.
