access violation exception
Question asked by James Mikel on Nov 11, 2015
Latest reply on Nov 13, 2015 by Jacob Corder
I am getting the following in the application events viewer.   the application accesses swCustomPropertyManager.GetNames() method without throwing an error...Not sure why the Get3-5 methods are causing the error below.  Please help.
Exception Info: System.AccessViolationException
Stack:
   at SldWorks.CustomPropertyManagerClass.Get3(System.String, Boolean, System.String ByRef, System.String ByRef)
This is a standalone windows application that that uses the .interop.sldworks.dll and interop.swconst.dll to open selected files and extract the custom and config specific properties.
I only get the error when running on the clients' system.
Client's system is Windows 7.  Solidworks 2015.
I have tried Get3, Get4 and Get5 all with the same results.  Any help would be greatly appreciated.
        public bool Export(String swFile)
            var success = true;
            ErrorMsg = String.Empty;
            swApp = new SldWorks();
            //MessageBox.Show("before open doc");
            swModel = swApp.OpenDoc6(swFile, p, s, "", ref nErrors, ref nWarnings);
            //MessageBox.Show("after open doc");
            if (swModel == null)
                ErrorMsg = "Model did not load";
                swApp.SendMsgToUser2("Assembly not loaded", stop, ok);
                swModel = null;
                swApp = null;
                RecordError(ErrorMsg);
                success = false;
            if (swModel.GetType() != p)
                ErrorMsg = "Selected SLDPRT file is not a part doc.";
                swModel = null;
                swApp = null;
                success = false;
            //MessageBox.Show("before rebuild");
            swModel.Rebuild(rebuild);
            //MessageBox.Show("after rebuild");
            try
                //MessageBox.Show("before save rebuild");
                swModel.Save();
                //MessageBox.Show("after save rebuild");
            catch (Exception ex)
                RecordError(ex.Message.ToString());
                success = false;
            cInfo = new Custom();
            //MessageBox.Show("Model: " + swModel.GetTitle().Trim());
            var title = swModel.GetTitle().Trim();
            if (title.Length > 7)
                if (title.EndsWith(".SLDPRT") || title.EndsWith(".SLDDRW"))
                    cInfo.DrawNo = title.Replace(".SLDDRW", "").Replace(".SLDPRT", "");
                else
                    cInfo.DrawNo = title.Substring(1, 4);
                    //sDrawno = Mid(swModel.GetTitle, 1, InStr(Mid(swModel.GetTitle, 4, swModel.GetTitle.Length), "-") + 2)
            else
                cInfo.DrawNo = title;
            try
                //MessageBox.Show("before GetCustomInfoNames");
                var cfm = (String[])swModel.ConfigurationManager.Document.GetCustomInfoNames();
                //MessageBox.Show("cfm count: " + cfm.Count().ToString());
                foreach (var ci in cfm)
                    switch (ci)
                        case "PROJECT NAME":
                            cInfo.ProjectName = swModel.GetCustomInfoValue("", ci);
                            break;
                        case "PROJECT NUMBER":
                            cInfo.ProjectNumber = swModel.GetCustomInfoValue("", ci);
                            break;
                        case "COLOR":
                            cInfo.Color = swModel.GetCustomInfoValue("", ci);
                            break;
                        case "PRODUCT NUMBER":
                            cInfo.ProductNumber = swModel.GetCustomInfoValue("", ci);
                            break;
                        default:
                            break;
                //swApp.CloseDoc(swFile);
                ErrorMsg = swFile + " custom info caused: " + ex.Message.ToString();
                success = false;
            finally
            lCS = new lConfigSpecific();
            try
                //MessageBox.Show("before ConfigSpecific Open Doc");
                swModel = swApp.OpenDoc6(swFile, 1, 1, "", ref nErrors, ref nWarnings);
                //MessageBox.Show("after Open doc");
                swApp.SetCurrentWorkingDirectory(swModel.GetPathName().Substring(0, swModel.GetPathName().LastIndexOf("\\")));
                //MessageBox.Show("after SetCurrentWorkingDirectory");
                var names = (String[])swModel.GetConfigurationNames();
                foreach (var name in names)
                    //MessageBox.Show("before Extension");
                    swModelDocExt = swModel.Extension;
                    //MessageBox.Show("after extension");
                    swCustomPropertyManager = swModelDocExt.CustomPropertyManager[name];
                    //MessageBox.Show("after CustomProperty");
                    //MessageBox.Show(name + " : " + swCustomPropertyManager.Count.ToString());
                    var ncs = new ConfigSpecific { Config = name };
                    var customProps = (String[])swCustomPropertyManager.GetNames();
                    //MessageBox.Show("after Custom Property GetNames");
                    foreach (string cp in customProps)
                        //MessageBox.Show("Inside Custom Props: " + cp);
                        String val;
                        String valout;
                        //bool resolved;
                        bool UpToDate;
                        switch (cp)
                            case "CONFIG WEIGHT":
                                UpToDate = swCustomPropertyManager.Get3(cp, false, out val, out valout);
                                MessageBox.Show(valout);
                                //status = swCustomPropertyManager.Get4(cp, false, out val, out valout);
                                ncs.ConfigWeight = Decimal.Parse(valout);
                                break;
                            case "CONFIG VOLUME":
                                ncs.ConfigVolume = Double.Parse(valout);
                                break;
                            case "QTY":
                                ncs.Qty = valout.ToUpper() == "TBD" ? 0 : Int32.Parse(valout);
                                break;
                            case "LOCATION":
                                ncs.Location = valout;
                                break;
                            case "SAW CUT":
                                ncs.SawCut = valout.ToUpper() != "NO";
                                break;
                            default:
                                var donothing = String.Empty;
                                //RecordError("Custom Property not handled: " + cp + " Drawing: " + swFile);
                                break;
                    lCS.Add(ncs);
                ErrorMsg = swFile + " config specifics caused: " + ex.Message.ToString();
                success = false;
            return success;
