I am trying to add a default mate reference to a weld nut so that I can drag and drop this into assemblies. When I select an existing circular edge and add the mate reference it works fine but I need to have the mate applied tangent to the projection surface so I added a split line to break the surface and add the mate reference there and it will not snap in place in the assembly now. Does anyone know of a way to make this work?
So what I ended up having to do was to create a cut extrude on the part and add the mate reference to the edge created by the cut. I put the cut in with a minimal thickness (0.00001") so that it is not noticeable on the part.
