I have built a chassis using structural members and done this 100's of times, but I am getting this non-linear edge invalid error on a linear edge when trying to insert bends?? What am I missing?
I have attached the part, I have used this procedure with success before and never encountered this error. I have checked that the edge is in fact a straight line so I am at a loss as to what the problem is. The purpose of doing this is to create templates for the laser cutter to cope the tubes.
Any help appreciated, thanks.
Good question Ben. I'm not sure why that doesn't work but if you add a boss extrude onto onto the face of each cut it does work. I added .05mm then selected the outside face of the boss extrude while "Insert Bends" and it works fine. I would send you a file but you apparently are using something earlier to 2014.
