I have a problem with making a thread for screw like part which is attached bellow.
And I can't find appropriate answer anywhere.
I actually found easy way by my self that works with no problems (I believe for any type of thread):
Divide sketch that should be swept-cut in two pieces. Problem was because it should look like continuous curved thread, and there was a problem with "zero-thickness". So idea is to divide it in two sketches and thus two swept-cuts, one for convex part, and one for concave part.
Hi Marko,
Nice solution you found. You are correct, the sweep is running into a zero thickness condition due to the equal pitch and profile heights. As Matt points out, you can easily create threads in 2016 using the new Thread command. I've taken your profile, split it in two (as you did), created Library Feature Parts out of them (this is what Thread uses for Profiles much like Structural Members), and created your threaded body.
I've attached the model and profiles for you if you (or anyone else) happen to have 2016.
Out of curiosity, what are you making with this type of thread on it?
Is there anything else aside from the profile that you add to the part to finish the thread?
Jody
