Hello All,
I'm having some trouble with a swept boss not following it's path. See attached part. As you can see, especially at the bottom of the coil, the profile does not follow the path. It is off by about .075" at the bottom of the coil. I've tried messing with the twist/orientation and path alignment with no success.
Can anyone help me out? Thank you in advance.
-Erik
...unfortunately... if you do not have a guide curve (gc) for this.. it will drift downward as it makes the travel to the end (just try a horizontal line and see).. ... that is, if it is pierced in the center.. it should do fine.
