3 Replies Latest reply on Nov 12, 2015 7:11 AM by Jean Stassen
    How to solve 64-bit compile error ?
    Jean Stassen
      When starting "SaveAsPDFwFolderSelection.swp" I get errorwindow below
      How can i solve this? I'm a BEGINNER in API and learning day by day
      Please find attached the macro wich i used and downloaded from the internet.
      btw I'm using SW2015 SP4.0
        • Re: How to solve 64-bit compile error ?
          Matt Martens
          The issue is the macro calls for the use of 32-bit functions from the Shell object library. You need to add PtrSafe to each of the 4 Function declarations in the "modBrowseToFolder" module.
          Private Declare PtrSafe Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As String) As Long
          Private Declare Function SHBrowseForFolder Lib "shell32" (lpbi As BrowseInfo) As Long
          Private Declare Function SHGetPathFromIDList Lib "shell32" (ByVal pidList As Long, ByVal lpBuffer As String) As Long
          Private Declare Function lstrcat Lib "kernel32" Alias "lstrcatA" (ByVal lpString1 As String, ByVal lpString2 As String) As Long
          That doesn't guarantee that it will work but will get you to a point where the code will compile.
              Simon Turner
              All the Longs need changing to LongPtr as well. For example:
              Private Type BROWSEINFO
                hOwner As LongPtr
                pidlRoot As LongPtr
                pszDisplayName As String
                lpszTitle As String
                ulFlags As Long
                lpfn As LongPtr
                lParam As LongPtr
                iImage As Long
              End Type
              Private Declare PtrSafe Function SHBrowseForFolder Lib "shell32.dll" Alias "SHBrowseForFolderA" (lpBrowseInfo As BROWSEINFO) As LongPtr
              Private Declare PtrSafe Function SHGetPathFromIDList Lib "Shell32" Alias "SHGetPathFromIDListA" (ByVal pidList As LongPtr, ByVal lpBuffer As String) As Long
              Private Declare PtrSafe Sub CoTaskMemFree Lib "ole32" (ByVal hMem As LongPtr)
              Private Declare PtrSafe Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As LongPtr, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As LongPtr
