I was wondering if anyone could help me out on how to make the assembly as shown in the drawing below. I have no problems with item 1 as it is a simple parts but the rest of the hose guide is made up of sheet metal with rounded corners and all of the sides flare outwards.
Any help would be greatly appreciated!!
Chris
Christopher,,, I made a solid model of something approximating the shape you show - material thickness. The dims are not exact but close. Did an offset surface (0) of top, bottom and sides then thickened (do not merge) to material thickness. Then did an "Insert Bends" on each thickened surface. You can flatten each one individually. I'm pretty sure this is how you should approach this. Attached a 2014 file. Perhaps this will give you some ideas.
Edit:.. You can easily modify the solid to get the dims you need.
