Hello, i've got a problem with the prjection type.. every time, i make a drawing it is always on third projection type... i changed it in first projection type and saved the drawing as a new sheet format. then, when i open a new drawing sheet it is again on third projection type!!!
please help!
Start a new drawing and set the required projection time. Save as drawing template and you may overwrite your existing drawing template.
