how to use the ViewDispRefPoints api
Question asked by Derek Eldridge on Nov 6, 2015
I'm just a user, not a developer. My visual basic understanding is minimal, but i've been able to use examples to create a few macros.
I'm trying to create a macro to turn off all of the View references. I DO NOT want to use the Hide all Types toggle. It aggravates me to go back to View/Hide all Types, then turn off all the individuals that i still don't want.
I used the "SetUserPreferenceToggle" to set all of the following:
     HideAll = False
     Planes = False
     Axes = False
     COORDINATE_SYSTEMS = False
     POINTS = False
     Curves = False
     SKETCH_DIMENSIONS_3D = False
     ALL_ANNOTATIONS = False
     SKETCHES = False
     LIVE_SECTION_PLANES = False
     ROUTING_POINTS = False
This is what i have so far:
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc
    Dim Output                      As Boolean
    Dim HideAll                     As Boolean
    Dim Planes                      As Boolean
    Dim Axes                        As Boolean
    Dim COORDINATE_SYSTEMS          As Boolean
    Dim POINTS                      As Boolean
    Dim Curves                      As Boolean
'    Dim PARTING_LINES               As Boolean
    Dim SKETCH_DIMENSIONS_3D        As Boolean
    Dim ALL_ANNOTATIONS             As Boolean
    Dim SKETCHES                    As Boolean
    Dim LIVE_SECTION_PLANES         As Boolean
    Dim ROUTING_POINTS              As Boolean
'    Dim CENTER_OF_MASS              As Boolean
     HideAll = False
     Planes = False
     Axes = False
     POINTS = False
     Curves = False
'     PARTING_LINES = False
     SKETCHES = False
'     CENTER_OF_MASS = False
    ViewDispRefPoints = False
    Set swModel = swApp.ActiveDoc
    Output = swModel.SetUserPreferenceToggle(swViewDisplayHideAllTypes, HideAll): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayPlanes, Planes): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayAxes, Axes): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayTemporaryAxes, Axes): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayCoordSystems, COORDINATE_SYSTEMS): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayReferencePoints, POINTS): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayCurves, Curves): Debug.Assert Output
'    Output = swModel.SetUserPreferenceToggle(swDisplayPartingLines, PARTING_LINES): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplaySketches, SKETCH_DIMENSIONS_3D): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayAllAnnotations, ALL_ANNOTATIONS): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplaySketches, SKETCHES): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayLiveSections, LIVE_SECTION_PLANES): Debug.Assert Output
    Output = swModel.SetUserPreferenceToggle(swDisplayRoutePoints, ROUTING_POINTS): Debug.Assert Output
'    Output = swModel.SetUserPreferenceToggle(swDisplayCenterOfMass, CENTER_OF_MASS): Debug.Assert Output
There are still quite a bit of things left on the list that are not covered under the "SetUserPreferenceToggle", or that are and did not seem to work.
View Origins
View Points
View Parting Lines
View 3D Sketch Plane
View Sketch Relations
View Grid
View Lights
View Cameras
View Decals
View Dimension Names
View Weld Beads
View Center Of Mass
I found that in particular View reference points is covered under "ViewDispRefPoints" and the API doc says it the following:
Visual Basic (Declaration)
Sub ViewDispRefPoints()
Visual Basic (Usage)
Dim instance As IModelDoc2   instance.ViewDispRefPoints()
Also under iModelDoc2 I found:
ViewDispCoordinateSystem
ViewDispOrigins
ViewDispRefaxes
ViewDispRefplanes
ViewDispRefPoints
ViewDispTempRefaxes
But I don't understand how to use them. Does this mean it's a function? If someone could give me a sample of how to use it in context, I think it would help alot.
The only sample i have is from another macro that uses the following:
Dim swApp As Object
Dim Part As Object
Set Part = swApp.ActiveDoc
Part.ViewZoomtofit2
Are those DIMs essentially building a path so the final command like this:
Application.SldWorks.ActiveDoc.ViewZoomtofit2
