I have legacy files that are at various revision levels 1,2,3 and so on. I want to bring them into EPDM and after they are in the system is there a way for the workflow to increment the appropriate revision so that if it is currently rev5 it will go to rev6 with a change of state though the workflow. currently have tried and even thought the properties follow on the data card and it says rev6, when I put it through the workflow it goes back to rev0
Yes this is possible but takes some work. You need to create one Transition for each increment of revision.
Then on each transition specify the increment Count
