We have recently started using a large number of forming tools in our new parts and i have been trying to use export to DXF to show the tool centres and orientation in a flat pattern. While all other form tools seem to show perfectly Louver Tools dont show up unless i show the punch itself which does not import nicely to my CAM software as they export lines that are not all on the same plane.
Is this a defect? or is there a specific way the louver Form tool needs to be drawn? i have tried using my own form tools as well as the solidworks supplied Examples with the same results.
You should be able to show the sketch in the feature which positions the feature. That means you'll want to show sketches in the drawing also. You can then dimension to that.
