Hi everyone
This is my first discussion so please forgive the unfamiliar and my poor english.
Because I'm Japanease.
My question is How do I get component name by selectionmanager When activedoc is drawing.
I want to get component name selected object on drawing.
The code I made before works well When activedoc is assembly.
But it dose not run When activedoc is drawing.
Here is my code
Dim bRet As Boolean
Dim strName As String
Set swModel = swApp.ActiveDoc
Set swComp = swSelMgr.GetSelectedObjectsComponent2(1)
strName = swComp.Name2
In drawing environment "swSelMgr.GetSelectedObjectsComponent2(1)" will return to you drawing view (swSelectType_e.swSelDRAWINGVIEWS)
It can be checked by typing:
If swSelMgr.GetSelectedObjectType3(1, 0) = swSelectType_e.swSelDRAWINGVIEWS Then
Therefore, a bit different approach is required for getting component in drawing environment.
