you can apply a bonded contact between the beam and the sheet (you cannot apply a no penetration contact between the face of a beam and a solid/shell so depending on how you want the contact to interact then the answer is either yes or no!
you could also consider using a shell mesh for the sheet material if you wish.
remember that because of the different ways that the calculations are carried out on beams and solids/shells you wont be able to see stress results for both at once.
Thanks your attention Dear Jamie.my problem is to find what is cause the result is incorrect.in this result you can show the plane not affected from acting force on joint from beam and not deformed and remained without deformation.thanks from your help.
