Re: Move Custom properties to specific configuration properties
Elmar Klammer Nov 4, 2015 11:28 AM (in response to Oren Wein)Hi Oren
This will get you started it copies configuration specific property to custom properties....SolidWorks MakroMania - Dateieigenschaften kopieren
Google translate will help translation. The rest is a little self-help.
Elmar
Deepak Gupta Nov 4, 2015 11:34 AM (in response to Oren Wein)I've used macros which are here on the forums (could not find the link or macro now) and they had worked great. So share the file or link of the one you're using and one can check/verify that.
Steven Dod Nov 4, 2015 1:22 PM (in response to Oren Wein)I do not have a macro for you to use but want to share that we only use the custom properties in our Solidworks files and EPDM. We rarely use configuration specific properties and EPDM works just fine with this. If you do not currently use configuration specific properties and do not really need them EPDM does not require them. You just have to set your variables to only look at the @ configuration (custom properties).
JOHN GEORGE Nov 4, 2015 3:19 PM (in response to Oren Wein)Oren,
This is one of the macro downloaded from one of the discussion (credit goes to Tapani)
Hope this works
Amen Allah Jlili Nov 4, 2015 4:29 PM (in response to JOHN GEORGE)This does not achieve what the OP asked. He want a macro that moves custom property (per model) to configuration-specific properties for a directory of models.
Deepak Gupta Nov 4, 2015 4:51 PM (in response to Amen Allah Jlili)Yes but this can be starting point and can be tweaked.
Oren Wein Nov 10, 2015 1:43 AM (in response to JOHN GEORGE)Hi All.
Thank you for your help. it is very helpful .
Is it possible to make this macro so I can make this copy to all parts,assemblies and drawings in the folder and subfolders without open them??? (like alex's macro).
Can you please help?? I will really appreciate it.
Thanks.
Oren.
Alex Volchok Nov 7, 2015 8:42 PM (in response to Oren Wein)Hi Oren and all,
Please download here a SolidWorks tool, which may help to manipulate custom and configuration specific properties.
Works without opening files and SolidWorks using SolidWorks Document Manager API.
It is a standalone tool, which may process all SolidWorks files in a folder and its sub-folders.
The attached version works for me using SolidWorks 2015 (I've performed a quick test).
Found in the SolidWorks Knowledge Base - (thank you SW support).
Enjoy,
Alexander
JOHN GEORGE Nov 11, 2015 5:17 AM (in response to Alex Volchok)Alex,
I tried to download the file from your link and it's not working
Can you please post the file here (if anyone downloaded?)
Thanks!
