Hello
I'm trying to design 4 flanges over a rectangle cutout feature like the attached image.
Is get it by the edge flange feature. But I have to sketch every flange and I can't apply a bevel to the corner.
What's the best way to design it?
Thank you in advance.
Regards.
You can use the end flange and then go back and edit the edge flange sketch. In the sketch the end lines are vertical/horizontal delete that relation and move the line a little bit and add an angle dimension.
