If you right click in the viewport of a model or drawing with out of date references and selection View you will see the following:
Is it just me or do those last two check boxes make no sense? If you deselect the 'Always Show Warning Watermark' then the 'Show Warning Watermark for this document only' becomes disabled (though it still shows the check mark) and the watermark disappears. If you select the last check box, and then deselect the first, the watermark disappears.
Can anyone provide a good explanation of what behavior is supposed to occur with the selection/deselection of these checkboxes?
Jim S.
Based on my understanding:
"Always Show Warning Watermark" This is more like a global set when you don't need watermark on anything in eDrawings.
"Show Warning Watermark for this document only" This is more related to particular document only. For e.g. you're using a document for presentation purpose and don't want the watermark to pop up but you still need the watermark for other documents.
