Has anyone else had a problem with the computational domain or meshing after cloning a project?
I've had this a couple of times now on different models, after running a project I clone it and change a boundary condition value, e.g. increase a mass flow rate, then try to re run it. When it tries to mesh it doesn't seem to see the model and just meshes the entire domain as fluid. If I then change the computational domain slightly (make it slightly larger in one dimension, save it, then reset it) it then meshes properly again.
Any ideas what is causing this?
I dont see any reported problems about that in the knowledge base.
What version and SP of SW are you running?
Janko Stellaard
Cadmes BV
The Netherlands
