Hi all,
I have prepared different layers and assigned different line thickness to each layers. But still i am not able to find the difference in output file _ PDF format.
my object and dimension lines are assigned with different line thickness properties.
but still i am not able to bring them up.
What settings should i make to make the line thickness visible.
Check #9 here: Frequently Asked Forum Questions . That particular question pertains to colors, but the same principles apply to line weights. Also, if it looks okay on your monitor but the problem happens when you save as pdf, then try printing to pdf instead (#7). If that doesn't fix the problem, please give more details.
