Is there a way to reference part data in an assembly drawing? For example, I have an assembly containing two parts from which I make a drawing. I want to reference metadata contained in one of those parts and not the assembly itself in my drawing notes. Typically I would use $PRPSHEET:"XYZ" to reference the data, but this will only pull from data stored in my assembly and not go down deeper into the part level. Seems like there should be some notation that would make this possible without having to add additional data at the assembly level duplicating data in the singular part files.
Any help would be appreciated! Thank you much.
Sam,
If you have views of the lower level part on the drawing sheet you can change the sheet properties to read form the desires view in the bottom left.
If you want to cheat, you can add that view off the sheet so it doesn't print.
