Macro for export PDF with revision
Question asked by Jan Veldheer on Nov 2, 2015
Latest reply on Nov 3, 2015 by Jan Veldheer
Hi guys,
I've searched on the forum but I couldn't find exactly what I want. I worked a few months with SW now (was an Inventor user)  and I love the macro-function.
I'm using an PDF-export macro for a while, but for now I needs a few things modified. So the macro should be modified because I want the revision value (custom property part) in de PDF document name.
What I want: "partname_Rev_A.pdf" (A=variable) when the part has an revision. If there is not an revision I want: "partname.pdf"
I've tried to modify the macro from Deepak ('Export Drawing as DXF_PDF (Revision).swp ------------- 12/15/14)
I got it working, but not without : _Rev_" Please help!
_______________________________________________________________________________________________________
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDrawModel     As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swView          As SldWorks.View
Dim nErrors         As Long
Dim nWarnings       As Long
Dim Revision As String
Set swDrawModel = swApp.ActiveDoc
If swDrawModel Is Nothing Then
        MsgBox "There is no active drawing document"
        Exit Sub
If swDrawModel.GetType <> swDocDRAWING Then
        MsgBox "Open a drawing first and then TRY again!"
        Exit Sub
Set swDraw = swDrawModel
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
If swModel.GetPathName = "" Then
        MsgBox "Insert a View first and then TRY again!"
        Exit Sub
Revision = swModel.GetCustomInfoValue("", "Revision")
If Revision = "" Then
        Revision = ""
Prop = ("Rev_")
        Prop = ""
swDraw.SaveAs3 Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) & Prop & Revision & ".PDF", 0, 0
