3 Replies Latest reply on Nov 3, 2015 4:52 AM by Amen Allah Jlili
    K Factor
    Hrituc Alexandru
      I try to make a macro to change value for K Factor and for the moment I didn't made it ... it's possible to create a macro like this?
        • Re: K Factor
          Hrituc Alexandru
          With this code i can modify only for mitter flange
          Option Explicit
          Dim Part As SldWorks.ModelDoc2
          Dim boolstatus As Boolean
          Dim FeatureData As SldWorks.MiterFlangeFeatureData
          Dim Feature As SldWorks.Feature
          Dim Component As SldWorks.Component
          Dim bData As SldWorks.CustomBendAllowance
          Dim nam As String
              Set Part = swApp.ActiveDoc
              ' Get the selected feature
              Set Feature = Part.SelectionManager.GetSelectedObject6(1, -1)
              ' Get the name of the selected feature
              nam = Feature.GetTypeName
              ' Get the feature definition
              Set FeatureData = Feature.GetDefinition
              ' Get whether to use default bend allowance to determine the current state
              Dim useCustom As Boolean
              useCustom = FeatureData.UseDefaultBendAllowance
              ' Get the custom bend allowance object
              Set bData = FeatureData.GetCustomBendAllowance
              Dim bType As Long
              bType = bData.Type
              ' Set the bend allowance type to deduction
              bData.Type = swBendAllowanceDeduction
              ' Set the value of the bend deduction
              bData.KFactor = 0.2841
              FeatureData.UseDefaultBendAllowance = False
              Call FeatureData.SetCustomBendAllowance(bData)
              ' Modify the feature definition
              boolstatus = Feature.ModifyDefinition(FeatureData, Part, Component)
            • Re: K Factor
              Hrituc Alexandru
              I succedeed!  ..here's the code:
              Option Explicit
              Dim FeatureData As SldWorks.SheetMetalFeatureData
              Dim nam As String
                 'Dim useCustom As Boolean
                 'useCustom = FeatureData.UseDefaultBendAllowance
                  Dim bType As Long
                  bType = bData.Type
                 'FeatureData.UseDefaultBendAllowance = False
