Hello everybody,
I'm involved in a load lifting by fork-lift problem. It's request to limit deformation of the load when lifted. Between loads and forks I have placed two "frames" in order to distribute load to forks. Anything in the solution is quite good but what is alarming is the graphic representation: Load deformation dosn't followes frame deformations as it's shown in the pics but one of the two loads penetrate both frames. Of course it's a scale effect...but even with a realistic scale the loads penetrate.
Just some information about model connections:
1) forks-frames: no penetration
2) frames-loads: no penetration (at first I modeled this contact as bounded but without any difference)
Is there anybody that can suggest what maybe happening?
ps: model is also attached.
Thank you.
I also don't see the two blocks penetrating the frame. Where do you see that occuring exactly? Don't only look at the colors, but use the probe function.
