How do I center the leader with the dimension? This takes up to much space and is not clear where it is pointing to
Another interesting issue. Looks like they will never end. I noticed that the hole callout comes in fine until I selected Dual Dimension. Then the text is offset to the top of the bent leader. I fiddled with the calloutformat.txt file a bit but could not alter this behavior. Then I found that if I go to the end of the line and hit enter twice the callout is aligned with the bent leader. I can't figure how you got 4 place decimal accuracy (in primary) though. Even tried changing standards. Can you give me a clue. I know it's not per ansi standard but I would like to know.
