I want to know how to create a geo file from a large FEA
model thatwas created in Geostar. I am a CosmosM user and
would like atutorial or an outline that descibes the steps to
create a geo filefrom a CosmosM database.
Think of geo file more as a script file, or an automated
wayto issue a command. You will have to build the model from
theground up, one command at a time.
When you create models in geostar it is often handy to save
sessionfiles (date the file name) after each session.
You havea *.ses file documenting all the commands that were
issued to buildthat model. This can be edited (any text editor),
merged, into asingle file. Change this file into a geo file by
changing theextension. To recreate the model you would then load
the geo fileand geostar will build the model using one command at a
time.
If the model exists the only thing you can do is alter the
modelusing geo files. Can't really rebuild it.
When you create models in geostar it is often handy to save sessionfiles (date the file name) after each session. You havea *.ses file documenting all the commands that were issued to buildthat model. This can be edited (any text editor), merged, into asingle file. Change this file into a geo file by changing theextension. To recreate the model you would then load the geo fileand geostar will build the model using one command at a time.
If the model exists the only thing you can do is alter the modelusing geo files. Can't really rebuild it.
Hope this helps.
