I'm cautiously entering deeper water with Design tables, thanks to the excellent pointers I've gleaned in this forum, but don't recall seeing any topics that mention the use of multiple pages (worksheets) in Design tables. I ran an experiment by creating a table with auto-create, added a worksheet (kept the default name of SHEET2), and linked the values on SHEET1 to cells on SHEET2. It worked with no apparent problems. Then, I saved the DT to a file, deleted the imbedded DT, and created a new external DT by linking to the saved file. Voila! It too worked fine. I'm still a little gunshy though, so this topic is to solicit comments from those of you out there who have more experience and perhaps have used multiple sheet DT's in more complex situations. Thanks in advance for your input. For your convenience, see the attached file.
I want to know is it possible to use multiple sheet in design table to link with multiple worksheet in the drawing for the different configuration. We can do it by created external DT, we have master design table and many Excel files in which the cells was consolidated from the master file, the in the drawing each configuration group has its own sheet with table inserted, my question is is it possible to di the same way by inbeded Excel.
thank
