When I receive a PDF file and try to open it the e-drawing
boxappears and says unsupported file. I have e-drawing viewer
andAdobe 8.1 installed. Any suggestions?
Without being able to explain what happened, exactly, I
thinnk I can help you fix it.
In Windows XP, right-click on one of your hijacked PDF's and select
'Open With=>Choose Program' from the context menu. In the 'Open
With' dialog box, you should see a list of installed programs with
Adobe Reader 8.1 listed near the top. If you do, then go ahead and
click the Adobe Reader selection and populate the checkbox labelled
'always use the selected program to open this kind of file.'
If Adobe Reader is not in the list, click the 'browse' button and
navigate to the 'Acrord32.exe' file (default location is c:\program
files\Adobe\reader 8.0\reader)
That should restore your program association.
John
In Windows XP, right-click on one of your hijacked PDF's and select 'Open With=>Choose Program' from the context menu. In the 'Open With' dialog box, you should see a list of installed programs with Adobe Reader 8.1 listed near the top. If you do, then go ahead and click the Adobe Reader selection and populate the checkbox labelled 'always use the selected program to open this kind of file.'
If Adobe Reader is not in the list, click the 'browse' button and navigate to the 'Acrord32.exe' file (default location is c:\program files\Adobe\reader 8.0\reader)
John
