Again, not sure if it's worth asking this with 2008 sp0 EV
but...
When rendering a SIMPLE models, I get a error that the file is too large and PW aborts?
ah,.... whatz-dat-about?
.. did you guys beta test this??? Never mind, dumb question.
I've seen the same error in all the beta and pre releases I have used. It's a bogus error though. If I close, open and re-render the file everyhting works fine.
I've also seen the "SolidWorks is running low on memory" error quite often when renering with PW. Again, closing SW and restarting takes care of the issue. Must be a memory leak in PW?
Rob
