so i have a part that i scaled down and when i do some faces end up missing. when i measured the width of the missing face it was .05". is that too small? here is a screen shot of what i am talking about.
Maybe you could try adding those missing surfaces by using surface commands? This does not address what/why the problem occurred but it could allow you to move forward.
the end goal is to print this on a 3d printer and therefore would need to be solid...would adding just a surface make that possible or would i have to thicken it or create a new piece that fits within that?
If the scaled-down model is shown in the feature-manager tree as a solid, you likely can just add an extrude feature to it to fill it in. After adding it and saving it a 3D-printer language (stl?) I would open the stl file in SW and run "import diagnosis" on it to be sure the file is ok rather than try to print it and get a bad surprise.
Just a thought -
Could you look at every extrude feature in the feature manager tree and edit to make sure you have the "Merge" box checked...
There could be just a tiny gap and your checker would not highlight that.
That should not be a problem. I would suggest running "check" (from tools tab) on the starting part before scaling down.
