I would like some insight on how some of you are handling
models of off the shelf components. Are you using revision control
on these models? For instance, I have an assembly model of a
purchased Thermistor that I created for use in my assembly designs.
In one assembly the two wires came straight out and then bent 90
degrees. This model was then sent through document control and
released. The design then changed and the wires had to follow a 3D
sketch. In your experience would a revision be applied to the
assembly model as there is now a new configuration of the model? We
are not using PDM at this time but how would PDM handle this? I
believe the program would automatically rev the model. I will be
pushing hard for PDM in the very near future as manually managing
the data SUCKS! Any help would be appreciaited.
Jeff
Jeff
Jeff
