Suppress or unsuppress the Flatten feature of Sheet metal part ?
Question asked by Li Feng on Oct 27, 2015
Latest reply on Oct 28, 2015 by Li Feng
Hi Budy,
As the topic said, I am using Macro (.swp) to suppress/unsuppress the flatten feature of a sheet metal part.
However, when I am using traversing method to get the flatten feature, it was always fail. while it ran very OK in selecting by click the flatten feature.
can you point out what is the problem ? thank you very much .
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>.traversing method>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    Dim swApp               As SldWorks.SldWorks
    Dim swModel             As SldWorks.ModelDoc2
    Dim swFeature           As SldWorks.Feature
    Set swModel = swApp.ActiveDoc
                If Not swModel Is Nothing Then
                    Set swFeature = swModel.FirstFeature
                    While Not swFeature Is Nothing
                    If swFeature.GetTypeName = "FlatPattern" Then  ' to detect if it is Flatten feature
                        Dim isSuppressed As Boolean
                            isSuppressed = swFeature.isSuppressed
                            Debug.Print swFeature.Name & "   IsSuppressed =   " & isSuppressed      ' it can always get the data here
                            If isSuppressed = True Then  'if it is suppresseed
                                swFeature.SetSuppression (1)  'then unsuppressed
                    swFeature.SetUIState swIsHiddenInFeatureMgr, False
                    swModel.EditRebuild3
                        Set swFeature = swFeature.GetNextFeature
                      Wend
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>.Selecting Method:>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    Dim swFeat As SldWorks.Feature
    Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
    isSuppressed = swFeat.isSuppressed
    If isSuppressed = False Then
        swFeat.SetSuppression (0)
    Else
       swFeat.SetSuppression (1)
