API Excel In Solidworks Macro
Question asked by Paul Johnson on Oct 27, 2015
Latest reply on Oct 27, 2015 by Elmar Klammer
I have and enclosure model that is driven by one central excel file.  The design tables which are part of the .sldprt or .sldasm are linked to this excel file.  I found this macro below which automates the open design table and close updating the .sldprt or sldasm files.  I lost the link so I can't give proper credit.  This works well, but when I duplicate the base files and want to point the links to a new central excel file I have to manually change the source files.
I haven't programmed in many years and am not grasping the VB.  I would like to modify this code to ask for the new excel file location, provide a way to terminate the program before proceeding and then open the excel file, change the linked pointer and update excel and close excel for each file with a design table.
Excel Macro:
Sub Macro2()
' Macro2 Macro
    ChDir "C:\LV Vault\NB\NBP000083_WallMount_HeatsinkExternal\Option2"
    ActiveWorkbook.ChangeLink Name:="HeatSinkExtWallMount_t.xlsx", NewName:= _
        "C:\LV Vault\NB\NBP000083_WallMount_HeatsinkExternal\Option2\HeatSinkExtWallMount_2.xlsx" _
        , Type:=xlExcelLinks
Working Solidworks macro that opens each solidworks file in an assembly that has a design table and updates the design table links.
Sub DesTblUpdate()
Dim swDoc As SldWorks.ModelDoc2
Dim swDocXt As SldWorks.ModelDocExtension
Dim DesTbl As SldWorks.DesignTable
Dim swAllDocs As EnumDocuments2
Dim FirstDoc As SldWorks.ModelDoc2
Dim dummy As Boolean
Dim NumDocsReturned As Long
Dim DocCount As Long
Dim DesTblCount As Long
Dim i As Long
Dim DoTheUpdate As Long
Dim sMsg As String
Dim bDocWasVisible As Boolean
Set swAllDocs = swApp.EnumDocuments2
Set FirstDoc = swApp.ActiveDoc
DocCount = 0
DesTblCount = 0
swAllDocs.Next 1, swDoc, NumDocsReturned
While NumDocsReturned <> 0
    Set swDocXt = swDoc.Extension
    If swDocXt.HasDesignTable Then
        DesTblCount = DesTblCount + 1
    DocCount = DocCount + 1
Wend
sMsg = DocCount & " Documents, " & DesTblCount & " of which had design tables"
sMsg = sMsg & vbCrLf & vbCrLf & "Do you want to update all these tables?"
DoTheUpdate = MsgBox(sMsg, vbYesNo, "Update Design Tables?")
If DoTheUpdate = vbNo Then
    Exit Sub
DocCount = 0
DesTblCount = 0
swAllDocs.Reset
        bDocWasVisible = swDoc.Visible
        swApp.ActivateDoc swDoc.GetPathName
        Set DesTbl = swDoc.GetDesignTable
        dummy = DesTbl.Attach
        dummy = DesTbl.UpdateTable(swDesignTableUpdateOptions_e.swUpdateDesignTableAll, True)
        DesTbl.Detach
        swDoc.Visible = bDocWasVisible
Wend
swApp.ActivateDoc FirstDoc.GetPathName
Thank you,
