How to avoid manual reopening of a cut-extrude feature in assembly after parameter change?
Question asked by F. R on Oct 27, 2015
Latest reply on Oct 27, 2015 by F. R
How can I avoid manually reopenning the cut-extrude feature, after changing equations values?
currently I am working on a model were the same part is multiple times inserted in the assembly.
Each part is rotated and then the cut-extrude tool is used in the assembly to make a rectangle.
But if the inclination of the ply's is changed - cut-extrude does not refresh (result below), even after ctrl+q or restart bothing happens. Only if the Cut-extrude feature is reopened manually change happens.
Any ideas how to avoid manually opening the cut-extrude featurw after equation parameter change?
