I would like to add a few features to the Design Library. One example would be Hole sizes for Pem Nuts. A common one we use needs a .249" hole. I would like to be able to just drag and drop from the Design Library the hole size needed for various PEM nuts, studs, and various other things. Rather than looking into the catalog to be sure the correct hole size is used.
How do I go about this?
Hi Keith,
For PEM holes I'd recommend using the hole wizard and saving the hole sizes as favourites so you can just select them from the drop down.
As far as Creating a library feature goes, create a folder in the design library (perhaps a new library also) Pin the library so it doesn't disappear, then you can drag features to the library. You can name the feature before you drag it to the library or you can rename it in there easily enough.
EDIT:
You can create more complex design library features like this How to create a SolidWorks Design Library Feature - YouTube
