Cavity Feature Scaling
Question asked by Eric Bunn on Oct 26, 2015
I pulled this code out of SW API help and want to find out how it could be converted to do a non uniform scale instead of a uniform scale.  I've modified it slightly to suit my application and it works.  I would ultimately like to scale each axis differently.
Please reference this code near the end.  This is where I want to specify x y and z values:
        Debug.Print ("New scale uniformly value: " & swCavityFeatureData.UseUniformScale)
        swCavityFeatureData.UniformScale = 1.04
Thanks in advance for the help.
Sub ScaleCavity()
    Dim swModelDocExt As SldWorks.ModelDocExtension
    Dim swSelectionMgr As SldWorks.SelectionMgr
    Dim swFeature As SldWorks.Feature
    Dim swCavityFeatureData As SldWorks.CavityFeatureData
    Dim boolstatus As Boolean
    Dim xScale As Double
    Dim yScale As Double
    Dim zScale As Double
    Set swApp = CreateObject("SldWorks.Application.23")
    swApp.Visible = True
    swApp.UserControl = True
    Set swModel = swApp.OpenDoc6("C:\DDPD\CAP Folder\Rhino Templates\Mold Body T.sldprt", swDocPART, 0, "", longstatus, longwarnings)
    Set swModelDocExt = swModel.Extension
'Select the Cavity1 feature and get and set its properties
    'boolstatus = swModel.Extension.SelectByID2("Mold Body T-1@Rhino Template - Top Bottom Config TB Mold", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
    swModel.ClearSelection2 True
    boolstatus = swModel.Extension.SelectByID2("Cavity1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
    Set swSelectionMgr = swModel.SelectionManager
    Set swFeature = swSelectionMgr.GetSelectedObject6(1, -1)
    Set swCavityFeatureData = swFeature.GetDefinition
        boolstatus = swCavityFeatureData.AccessSelections(swModel, Nothing)
        Debug.Print ("Scale type: " & swCavityFeatureData.ScaleType)
        Debug.Print ("Scale uniformly value: " & swCavityFeatureData.UseUniformScale)
        swCavityFeatureData.GetScale xScale, yScale, zScale
        Debug.Print ("Scale values:")
        Debug.Print ("  X: " & xScale)
        Debug.Print ("  Y: " & yScale)
        Debug.Print ("  Z: " & zScale)
        Debug.Print ("Value by which to scale this cavity feature in all directions: " & swCavityFeatureData.UniformScale)
        Debug.Print ("")
        swCavityFeatureData.UseUniformScale = True
        Debug.Print ("New value by which to scale this cavity feature in all directions: " & swCavityFeatureData.UniformScale)
        boolstatus = swFeature.ModifyDefinition(swCavityFeatureData, swModel, Nothing)
