0 Replies Latest reply on Oct 26, 2015 6:48 AM by roberto gennari
    FACES COINCIDENT IN INTERFERENCE DETECTION?
    roberto gennari
      Hallo,
      my requirement is to coloring of green all the faces that have a matching contact between them, NOT an interference.
      To do this I edited a macro for interference checking.
      the macro works but not very well, in fact I color also faces that should not?
      Can someone help me overcome my mistakes?
      This is my macro:
      Option Explicit
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swAssy                      As SldWorks.AssemblyDoc
          Dim swSelMgr                    As SldWorks.SelectionMgr
          Dim CompArray()                 As SldWorks.Component2
          Dim swSelData                   As SldWorks.SelectData
          Dim vCompArray                  As Variant
          Dim vIntCompArray               As Variant
          Dim vIntFaceArray               As Variant
          Dim swFace                      As SldWorks.Face2
          Dim swEnt                       As SldWorks.Entity
          Dim swComp                      As SldWorks.Component2
          Dim i                           As Long
          Dim nSelCount                   As Long
          Dim bRet                        As Boolean
          Dim vFaceProp                   As Variant
          Dim swModelDocExt As SldWorks.ModelDocExtension
          Const bCoincidentInterference   As Boolean = True
          Set swModel = swApp.ActiveDoc
          Set swAssy = swModel
          Set swSelData = swSelMgr.CreateSelectData
          Debug.Print "File = " & swModel.GetPathName
          nSelCount = swSelMgr.GetSelectedObjectCount
          ReDim CompArray(nSelCount - 1)
          For i = 0 To (nSelCount - 1)
              Set CompArray(i) = swSelMgr.GetSelectedObjectsComponent2(i + 1)
          Next i
          vCompArray = CompArray
          swAssy.ToolsCheckInterference2 nSelCount, (vCompArray), bCoincidentInterference, vIntCompArray, vIntFaceArray
          If (IsEmpty(vIntCompArray) = True) And (IsEmpty(vIntFaceArray) = True) Then
              Debug.Print "  No contact"
              MsgBox "Nessun contatto, l'applicazione esce"
              Exit Sub
          If Not IsEmpty(vIntFaceArray) Then
                  Debug.Print "  " & UBound(vIntFaceArray) + 1 & " Faces interfere!"
                  swModel.ClearSelection2 True
                  For i = 0 To UBound(vIntFaceArray)
                      Set swFace = vIntFaceArray(i)
                      Set swEnt = swFace
                      Set swComp = swEnt.GetComponent
                      Debug.Print "    CompFace[" & i & "] = " & swComp.Name2
                      'bRet = swEnt.Select4(False, swSelData): Debug.Assert bRet
                          vFaceProp = swEnt.MaterialPropertyValues
                                  'vFaceProp = swModel.MaterialPropertyValues: Debug.Assert Not IsEmpty(vFaceProp)
              'bRet = swModel.SelectedFaceProperties(RGB(0, 255, 0), vFaceProp(3), vFaceProp(4), vFaceProp(5), vFaceProp(6), vFaceProp(7), vFaceProp(8), False, ""): Debug.Assert bRet 'VIOLA EROSIONE
                  Next i
              Else
                  Debug.Assert Not IsEmpty(vIntCompArray)
                  Debug.Assert False = bCoincidentInterference
                  Debug.Print "  Faces touch but not checking for coincident interference!"
          If Not IsEmpty(vIntCompArray) Then
              Debug.Print "  " & UBound(vIntCompArray) + 1 & " Components interfere!"
              For i = 0 To UBound(vIntCompArray)
                  Set swComp = vIntCompArray(i)
                  Debug.Print "    Comp[" & i & "] = " & swComp.Name2
                  'bRet = swComp.Select2(True, 0): Debug.Assert bRet
              Next i
