Hello, I'm new to this so I might be unclear
In my class I work in millimeters, and everything works just fine, but when I'm using SW in my laptop, using the same units resulting me in an extremely small sketch that I can't even see.. and I'm using the exact same units!
p.s. I tried to go to the units options and set it to MMGS beforehand.
Any idea why is this happening?
Hello Rom,
I'm not sure why your sketch is coming in small initially. It might have something to do with the way your template was saved. I'd suggest zooming in so that your first sketch is about the right size, then delete everything and re-saving your Part template. I'm not sure that will work, but it's worth a shot. In the meantime I assume you know you can zoom in and center your model / sketch with the F key?
