print to pdf silent
Question asked by Shaun Jalbert on Oct 23, 2015
I posted a similar thread but have have decided to change directions - sort of.
I'm in need of a macro to Print to PDF (Not to be confused with Save as PDF). It must be, no matter what, a "Print as PDF" macro because my manager absolutely refuses to permit  us to use the "Save as PDF" option because of some printing issues recently.
The code below is what I have to work with, but I'm having some issues getting some standards nailed down.
1) At the very least, I need the print specification in the script to set the options as shown in the attached image below. How can I do this?
Right now, the script works, but my scales are off and adjusting the values below don't seem to have any effect.
    printSpec.FromScale = 1
    printSpec.ToScale = 1
2) This is more of a wishlist item, but if its possible, it would be amazing if this script could run silently, naming the PDF as the SolidWorks file name (minus the "layout" or "sheet name" as the PDF automatically adds this) and then save it in a predetermined folder on the Users desktop called "Export". Can this be done?
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swPageSetup As SldWorks.PageSetup
Dim printSpec As SldWorks.PrintSpecification
Dim drawing As String
Dim errors As Long
Dim warnings As Long
Dim footerTextNumber As String
Dim footerTextCount As String
Dim footerText As String
Option Explicit
    Set swModel = swApp.ActiveDoc
    Set swModelDocExt = swModel.Extension
    'Create a print specification
    swModel.Printer = "Adobe PDF"
    Set printSpec = swModelDocExt.GetPrintSpecification
    printSpec.ConvertToHighQuality = True
    printSpec.AddPrintRange 1, 1
    printSpec.ScaleMethod = swPrintSelection
    printSpec.PrinterQueue = ""
    printSpec.PrintToFile = False
    Debug.Print "Printing specifications:"
    Debug.Print "  Collate: " & printSpec.Collate
    Debug.Print "  Convert to high quality: " & printSpec.ConvertToHighQuality
    Debug.Print "  Current sheet: " & printSpec.CurrentSheet
    Debug.Print "  From scale: " & printSpec.FromScale
    Debug.Print "  To scale: " & printSpec.ToScale
    Debug.Print "  Number of copies: " & printSpec.NumberOfCopies
    Debug.Print "  Print background: " & printSpec.PrintBackground
    Debug.Print "  Print cross hatch on out-of-date views: " & printSpec.PrintCrossHatchOnOutOfDateViews
    Debug.Print "  Printer queue: " & printSpec.PrinterQueue
    Debug.Print "    File: " & printSpec.PrintFile
    Debug.Print "  Print white items black: " & printSpec.PrintWhiteItemsBlack
    Debug.Print "  Selection as defined in swPrintSelectionScaleFactor_e: " & printSpec.ScaleMethod
    Debug.Print "  Total sheet count: " & printSpec.SheetCount
    Debug.Print "  X origin: " & printSpec.XOrigin
    Debug.Print "  Y origin: " & printSpec.YOrigin
    ' Print the drawing to your default printer
    swModelDocExt.PrintOut4 "", "", printSpec
    printSpec.RestoreDefaults
    printSpec.ResetPrintRange
Shaun
