I'm having a problem getting an install from an administrative image to work. It starts and almost immediately goes to the screen saying 'cancelled'. I've attached the install log file as well, though probably not helpful considering how generic the error looks.
Anyone else had this issue or been able to successfully install from a 2016 admin image?
Tried on Windows 10 & Windows 7. With & without virus scanner enabled.
*edit: I skimmed too quickly some serial numbers were in the log files. I'm just removing them. The pertinent line seems to be:
"INTERNAL ERROR: EXCEPTION in InstallNext!"
Don't share log blinding on public forums with removing the serial number from them.
Can you recreate the admin image? Also make sure you've admin right before you make image OR install from image.
