I'm trying to dimension a part with two auxiliary views. They are only 2 degrees off of each other so it isn't immediately clear which view is at which angle. I can't connect an angle dimension to the Arrow line like you can when doing a Section View. Any ideas?
John
It's always better to post if you can, but that said, I wing something at you from the dark...
If you can, snap sketch lines to the required edges in the view and dimension to these.
I hope this helps.
Cheers,
Kevin
