Ctrl+select does not select more than one item at the time? Any suggestion on how to make the command work as was meant to work (multiple selection)?
let say I try to select more than one dimension of a component in order to make a new configuration of it.
I assume you're selecting the dimensions from the graphics area, and then right-clicking and choosing "Configure Dimension" from the drop-down? If so, then that's one of the few times I'm aware of where I believe you're right. However, after selecting the first, then when the table comes up you can double-click on the dimensions to add them to the table.
Welcome to the forum. It does usually select multiple entities. What are you trying to select?
