We've been performing "Save as PDF" for creating all of our PDF's but ran into some issues recently and now management wants us to "print to PDF" instead.
For our save as PDF, we had a handy little macro that:
1) ran the save as PDF command.
2) saved the PDF to a specified location.
Is it possible to manipulate our API code to do this again, but launch the "Print as PDF" command instead?
Another issue is that we require the PDF file to be full scale - so is there an option for that too?
Below is our previous code for reference:
Dim sFileName As String
Dim sPathName As String
Dim strFullPath As String
Dim bRet As Boolean
Dim nErrors As Long
Dim nWarnings As Long
Dim Path As String
Set swModel = swApp.ActiveDoc
sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
sFileName = Left(sFileName, InStrRev(sFileName, ".") - 1)
sPathName = Environ("USERPROFILE") & "\Desktop\Export\"
If Dir(sPathName) = "" Then
MkDir sPathName
sPathName = sPathName & sFileName & ".PDF"
bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
Beep
If bRet = False Then
swApp.SendMsgToUser2 "Problems saving file.", swMbWarning, swMbOk
Public Function FolderFromPath(strFullPath As String) As String
Dim I As Integer
strFullPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") - 1)
For I = Len(strFullPath) To 1 Step -5
If Mid(strFullPath, I, 1) = "\" Then
FolderFromPath = Left(strFullPath, I)
Exit For
Next
End Function
Macro do Print as PDF
