MWMarty Winters20/10/2015
I can't seem to move BOM's within a drawing feature tree so that match up with the sheet they are on (things go out of order as I added sheets and rearranged). I can drag sheets to rearrange them but not BOM's. Also, is there any way to rename a BOM? It is hard to figure out which bill of material is on a sheet. When I select a BOM on the sheet, it doesn't highlight the BOM in the feature tree, nor show the name of the BOM in the property manager window (and no "properties" option in the drop down menu). The only way I have figured out to identify which BOM is on a sheet is to select each BOM in the feature tree until the one on the sheet highlights.
Marty
