I did look at your sketches and one thing needed is the amount of line segments need to be the same in every sketch for the loft to be smooth, find the sketch with the most line segments and make the other sketches the same number.
If you have just a circle use the Split Entities tool to split the circle into the same amount of line segments as the sketch with the most.
