Hi, Is it possible to add additonal dimension values to a dimension text like in Pro-engineer, where you use @value?
I want to add the PCD value of a hole pattern to the hole dimension.. (not the callout)
The only way I have found (new SW user after 20 years of Pro/E) is to make a note with something (anything) in it, then click the dimension(s) you want and they get embedded into the note.
So a note that says:
<click> THRO EQUISPACED ON A <click> PCD
should do the trick.
Cheers,
John
