I performed a clean installation of SolidWorks 2016 SP0. The installation proceeds without any problems.
However, I try to access the simulation module and it appears the error:
And if I try to load the module SolidWorks Toolbox and it appears the error:
I repaired the installation and continuous error.
Is someone in the same situation?. How I can resolve the error?
How many SW have you installed on your machine?
If multiple versions are installed, make sure that the path through which SW is trying to access the dll file is right.
You can also manually load the respective dll files by below mentioned procedure
SW -> File -> Open -> Set File Type to 'Add-Ins(*.dll)'-> Go to C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\Simulation and you should find cosworks.dll -> Open it.
Same procedure for Toolbox.
