I wanted to know if studs can be found as standard parts or do we need to create models. It would be much easier to import ready models in the fixture
Hi Abilash,
Metric studs are also available in Toolbox if you have SOLIDWORKS Professional or higher. You can find them in the ANSI Metric, DIN, GB, and JIS standards under the Bolts and Screws folder. If you need them in a different standard you can copy the hardware to the desired folder or drag them to the new (for 2016) Favorites folder.
Jody
Hi Abilash,
Jody
