Blank size cells in hole table?
Question asked by Aaron POE on Oct 16, 2015
Latest reply on Oct 16, 2015 by Dennis Bacon
I know this has been a long running issue in Solidworks, but is there a way to get non-circular holes (I am using square holes for carriage bolts) to be automatically populated in the size column of the hole table? I can't find any suitable substitutes in the hole wizard. As you can see in my image, about 90% of the blank size cells are actually the same size square holes. So not only is the size not populated, but it wont combine same size holes into one tag because there is no size information. Is there a "simple" work around without having to manually enter the information and manually update it when there are changes made to the part? As you all already know this gets very time consuming and aggravating. Thanks in advance for the help.
I found the caption below on the 2013 Solidworks Help forums. I wasn't sure if this had been addressed or not since then.
