Change Drawing Text from Bold to Regular?
Question asked by Patrick Malone on Oct 16, 2015
Latest reply on Oct 20, 2015 by Patrick Malone
Upfront I will state this, limited programming knowledge.
I've done some auto lisp (Autocad) programming so
I understand some programming concepts.
VBA/API are new waters that I am stepping into so it won't take much to exceed my knowledge base at this point.
I am starting off by recorded macro...
Here is what I have.
' macro recorded on 10/16/15
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Sheet2", "SHEET", 0.838669660377358, 0.44465719245283, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("DetailItem2219@Sheet Format12", "NOTE", 0.703758615709871, 3.44084042712842E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2217@Sheet Format12", "NOTE", 0.728801374375636, 3.47156773837475E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2176@Sheet Format12", "NOTE", 0.759682322178205, 3.37938580463574E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2221@Sheet Format12", "NOTE", 0.826360587582757, 3.42547677150525E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2216@Sheet Format12", "NOTE", 0.708367712396822, 2.35002087788344E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2175@Sheet Format12", "NOTE", 0.797784188123663, 2.61120302347731E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2216@Sheet Format12", "NOTE", 0.73279592483766, 2.48829377849196E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2220@Sheet Format12", "NOTE", 0.829740591819854, 2.54974840098463E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2229@Sheet Format12", "NOTE", 0.708674985509285, 1.55111078547867E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2226@Sheet Format12", "NOTE", 0.750003219135609, 1.55111078547867E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2228@Sheet Format12", "NOTE", 0.738941387086927, 1.50501981860916E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2227@Sheet Format12", "NOTE", 0.783035078725421, 0.015357471298555, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2222@Sheet Format12", "NOTE", 0.795326003223956, 1.52038347423233E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2223@Sheet Format12", "NOTE", 0.808538747059881, 1.61256540797134E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2225@Sheet Format12", "NOTE", 0.818371486658709, 1.42820154049332E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2224@Sheet Format12", "NOTE", 0.829433318707391, 1.50501981860916E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem84@Sheet Format12", "NOTE", 0.741287052720168, 0.551920199589513, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem85@Sheet Format12", "NOTE", 0.721665405361847, 0.552279132163141, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem83@Sheet Format12", "NOTE", 0.659330781741816, 0.552159487971932, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem86@Sheet Format12", "NOTE", 0.687686455058414, 0.549527315765328, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem88@Sheet Format12", "NOTE", 0.730279787128915, 0.548689806426863, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem88@Sheet Format12", "NOTE", 0.745953176177329, 0.548689806426863, 0, True, 0, Nothing, 0)
Part.EditSheet
Part.EditSketch
Part.ViewZoomtofit2
It appears to touch these objects but it does not change any of them.
Nothing in the code suggests any property change (specifically to Regular)
I selected several similar text objects, went to the Note properties, picked Font,
on the Choose Font dialog I only changed the text style from Bold to Regular.
Selected several more similar text objects, repeat...
Selected several more similar text objects, repeat....
This was at least 5 different "selection sets"
in each drawing sheet the text items are in the same placement.
Having to correct some legacy drawings and this would save quite a bit of time...
I am not sure where to start
Here are the same steps with just fewer objects in case it makes it easier to assist me..
Dim swApp As Object
Dim Part As Object
Set swApp = _
boolstatus = Part.Extension.SelectByID2("Sheet2", "SHEET", 0.751470654740781, 1.51601575968275E-02, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
boolstatus = Part.Extension.SelectByID2("DetailItem2229@Sheet Format12", "NOTE", 0.707642546161755, 1.54023018431205E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2226@Sheet Format12", "NOTE", 0.74808063529268, 1.54023018431205E-02, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2222@Sheet Format12", "NOTE", 0.794088042088343, 1.54023018431205E-02, 0, True, 0, Nothing, 0)
Part.EditSheet
Part.EditSketch
Part.ViewZoomtofit2
